rebuilt a4ld not working well
Momohenri
Hogne Belgium
Hello, here I rebuilt my a4ld gearbox but I have a problem, I have to go up to 2500 turns for it to move forward or backward, I'm not sure to the band setting, my question is: is it that it can come from there and if so it is necessary to tighten or relax the bands? , if you think that it can come from other things do not hesitate to give me your opinion a +
Doesn’t sound to be a band issue. Several things can give the symptoms you described. Low fluid, filter missing or damaged O rings, pressure regulator valve sticking. Need to get a pressure gauge on it and get some readings to help diagnose.
Brad
Hello, thank you for the answer, I have redone the level and now it is moving well but I think I start in 2 in forward gear, it does not move backwards and apparently not in 1, I checked if the servo piston was pressing the low / reverse band and it's in place, any idea? and I hear a broth when I put gas
