I have a 95 Ranger Super Cab with 4.0, 225k, 4" lift, 31x10.5, 2 wheel drive. A few year back I swapped the 7.8" rear axle for a 95 explorer 8.8". The transmission was blow by from the pump (more info from older post below), but I have just lived with it and put another 75K on it. But now it is time to do something; so my question is with this setup do I just rebuild the A4LD or is there something better I could swap to? I have a pretty good shop so fab work would not be a problem, this is not my field so I thought I would ask the experts.
"Default 95' Ranger Transmission shutter or hesitation
I have a 1995 Ford Ranger 4.0, 2wd, automatic transmission and at low speed in high gear it will shutter or hesitation from about 1500 rpm up to 2500 rpm. I pull a boat with it and have no trouble pulling the boat; I think it is because the added fuel increases the hydraulic pressure on the solenoids in the transmission. Does this sound right? If so can I just change the solenoid or solenoids? Also, are the solenoids controlled by a sensor or computer module? If not what is it and how do I fix it?
Thanks,"
Thanks again,
Thanks,"
Thanks again,
