rear long travel
camdenthekid
Folsom, California
im thinking about putting a blitzkrieg motor sports long travel kit on my truck
and im not sure what to do about the rear end
what would be the easiest way to build up the rear to match the front travel and have the truck sit correctly
ive looked into a 4 link but im not sure if i want to under take the 4 link
any suggestions would be much appreciated
u can always get a set of long travel leafs and flip your shackle mounts. You will gain more hight and make the truck sit a little better with the leafs, also gain more travel. By flipping your shackle mounts your goin to lose about 2" of your hight but gain even more travel .
give blitz a call and they can help you out the most. if not go to dezertrangers.com USE THE SEARCH button before you ask this question. you will get so much s**t for it.
also call up deaver and national they will also be lots of help.
You must be a member too ;)
thanks guys
i think i changed my mind about the 4 link and am probably going to end up doing it anyways when i get the long arms
but i might do the shackle flip and leifs for the time being
