- Jul 13, 2013
- Automatic
I'm in the same boat as you with my B2 rear end making horrible noises. Pretty sure the pinion bearing is out since I can move the pinion around in the housing. D: It's been like this awhile so I'm assuming that the ring gear is also in a bad way because of this. For about the same money I can replace the 7.5" 3.73 in my rig with a low mileage used 8.8 with 4.10's and disc brakes (woot!) out of an Explorer. From what I've seen I have to hack off the leaf spring pads and install new ones, fab up shock mounts and then figure out the driveshaft situation. There are also better options for lockers, spools, etc for the 8.8. Of course, this leads to having to get a D35 in 4.10 for the front, and a locker of some sort for it and then... well you get the idea. It never really ends. Keep in mind that my B2 is our extra vehicle, so it's no big deal if it sits for a month waiting for parts or something. Also, I bet you can find a complete used 7.5 to swap directly in for about $300 on car-part.com
