Rear bumper with a body lift?
Kyle M.
GOING FOR BROKE
OTOTM Winner
Solid Axle Swap
Howard City Michigan
What do you guys do with them? I don't like how low it is and the brackets don't allow and fudging. I was thinking about getting a roll pan, but if i can move them bumper up easily, I will just do that for now.
Thanks
You should be able to get or make some new brackets that lift the bumper to match your body. Most new body lift kits come with them so if you contact anyone who sells them they should be able to sort you out...
If you have access to a welder I say just take two pieces of metal, cut them to the desired length, and put two holes in both sides along with two holes in the bumper bracket. Bold it up and then presto, bumper is raised. Might need to bend the plate a bit to get it to fit.. not sure.
Or are the bolts vertical? I can't remember.. this idea works with only horizontal bolts.
get so piping and make the brackets from the stock mounts
The bolts are vertical, so it isn't too easy
I just wanted to know if they was a simple solution. I am in the process of make a new rear bumper, so no worries now. I will post pictures of it when I am finished.
Thanks anyway!
