stableboy
Hi,
Local garage put in a boneyard 4.0 in my 2003 FX4 after the cam chain tensioners grenaded. Moved since then and after several weeks a rattle developed - sounds like passenger side rear. It does NOT sound anything like the tensioner rattle before it self destructed and pretty much disappears once hot. Engine runs and sounds great otherwise. Exhaust system is tight. I've heard similar sounds from loose flex plate bolts. Is there a simple way to check? Going under it now to see if there is a dust cover/inspection plate on bell housing. Thanks!
