INFO Ranger junkyards
Joshrose
Bowling green ky
Does anyone know of any good ford ranger salvage yards with in a 2 hr drive of bowling green ky I’m needs parts of the harness that goes from the main harness to the transmission and various other places and can’t seem to find anything online for what I’m needing
Here's some. I plugged in a search for a common part, a front fender. These yards do not put every little part in the database. But if they have a popular part like a fender, they most likely have the rest of the truck there and you can get some other parts off of it.
1991
Fender
RH,SILVER EXT
X​
T045P
$45​
Dave's Auto and Truck Parts USA-KY(Morehead) Request_Quote 800-432-9841 Request_Insurance_Quote
Live Chat
260​
1990
Fender
A
0​
6G2986
$50
actual
Williams and Tucker Auto Parts Inc. USA-KY(Sulphur-Well) Request_Quote 1-800-545-0687 Request_Insurance_Quote
Live Chat
395​
1992
Fender
A
0​
183183
$50
actual
Live Chat
395​
1989
Fender
Ford Bronco II
000,RED,2DR,
000
A
0​
210295
$50
actual
Masterson Auto Parts USA-KY(Irvington) Request_Quote 1-800-405-0963 / 1-270-547-2778 Request_Insurance_Quote
Live Chat
419​
1990
Fender
Ford Bronco II
RH-BLUE-GOOD SHAPE
000
A
0​
1382
$60
actual
Hayes Auto Parts USA-KY(Bowling-Green) Request_Quote 270-843-4889 / 270-843-1762 Request_Insurance_Quote
Live Chat
436​
1990
Fender
RH,,WHITE,,GOOD FOR YEAR
000
A
0​
162762
$Call​
Live Chat
436​
1991
Fender
RED
000
A
0​
JH0677
$75
actual
Mike's Used Cars & Auto Parts - Russellville USA-KY(Russellville) Request_Quote 270-725-9161 Request_Insurance_Quote
Live Chat
466​
1992
Fender
RH,MAROON EXT,EL
X​
6425
$65​
Universal Auto Recycling USA-KY(Benton) Request_Quote 1-270-527-3431/1-800-443-8578 Request_Insurance_Quote
Live Chat
543​
1991
Fender
RH,SILVER EXT,
000
A
0​
00538
$75
actual
Lane Road Auto Salvage USA-KY(Paducah) Request_Quote 1-800-685-6757 Request_Insurance_Quote
Awesome thank you I’m needing a harness part for the transmission that connects the main harness to the sub part of the harness that connects to the transmission
Then you might be able to narrow the results by going to the above site (www.car-part.com) and looking for a transmisson for your truck that is the same type. If they have the transmission on the shelf, there is a chance the rest of the truck may still be in the yard.
I wish you luck. Those harnesses are extremely year specific. There is a yard local to me that would be within your search radius.
Qualls Auto Salvage
They usually have about 8 Rangers on the back lot. Nothing out there is cataloged but your welcome to look yourself.
Qualls Auto Salvage
Where would it be located I’ve looked at some of the yards in Nashville
190 Trent Rd, Lafayette, TN 37083
If you can post pictures of what the connectors look like on both ends of the harness you need, I'll drive by and take a look in the morning when I get off work.
It's only a couple miles out of my way home.
I don’t have photos of the connectors but I can definitely describe what I’m needing lol it plugs into this both of them and goes various places under the hood they are located near the washer fluid reservoir on the driver wheel tub one of the wires runs down the the neutral safety switch on the 89 a4ld auto transmission and plugs into a 4pin plug photo of that 4 pin connector is also included
It should plug into the 6pin and the 4pin on the other end and go god knows where
Sorry I haven't been online in a couple days. I'll cruise by tomorrow morning.
Will this work?
It's on a 92 with 4.0 and A4LD.
You'll need a scissor jack I think to get to the connector on the transmission. Or a really thin arm to reach between the body and transmission.
The other wires are pulled loose already. One goes the oil level switch (that connector is broken) and the other to the oil pressure switch. The remainder goes straight to the transmission.
It's at Quall's. I would've gotten it for you, but was ill equipped to reach that final connector. The truck is laying on axles, no wheels. I didn't think to see if it could be reached through the shifter plate hole in the floorboard.
It will be Monday but I’ll swing down there and take a look and try to get it thank you for going and looking
