Hmm, if you bought something from a store that was defective, do you expect someone from the store to drive to your house to replace it or give you a refund?you said you wouldn't come get it...
Whether or not you're in the right, it would be a good idea to make it possible to make good. Two hours isn't THAT far. Is it really worth it? I've been known to drive 3-4 hours (one way) looking for junkyard parts.
Maybe the two of you can split the difference and meet halfway? Mike, you should be concerned that you're not 100% in the right here, and it can cause you more trouble than it's worth over 2-4 hours. I guarantee you'll spend a lot more time than that in court even if you win, if you let it go that far.
Well, if nothing else it sounds like he offered you a refund here.
Perhaps take him up on it?
I'd be skeptical as well -- or I'd at least want to see what happened -- if I got a report like yours. Not everything that can go wrong is bad setup, but some things are. I'd want a look at the contact pattern, as that can tell the difference. I'd also want a good look at spider gears and the old lubricant, and would want to feel the pinion and axle bearings.
yea well i'm leaving for vaca. i'll be back in a week
Mike, I just got back home... If you are willing to throw me some extra money back for bringing the rear back I will. I'm not asking for 100 extra bucks just something to compensate me for my gas, time and money I already put into the rear. When you put the rear into another truck you can hear the whine first hand. If you would have offered me money from the beginning to bring it back I would have... and I still will.
Mike your a fuckin prick, karma is a bitch... I wish i'd be there to laugh in your face when it happens... I didn't think you were but I guess you are an asshole
Jspafford, there is quite a lot more to this than new parts. If he didn't set it up correctly, the new parts will not survive break-in. If this were an alternator, that approach would work great.
And it does NOT sound like he knows what he's doing. I'd insist on an inspection -- perhaps from a neutral third party at 89's expense if he doesn't want to trust Mike.
I think an original setup error is fairly likely, but far from a certainty. An example of something else that could go wrong, leading to very rapid failure, is water contamination from a deep water crossing, especially if the vent wasn't hooked up correctly. It is VERY suspicious that 89 is not cooperating with this. 2 hour drive or not; I'd take a 2 hour drive for a few hundred bucks.
Mhughes sold the axle to 89 stating it was a fresh rebuild by a professional shop. However in the first post from what I can tell he asks about notching the pin. It sounds to me like he was checking up to make sure what he did was right. Which makes it sound like he did the rebuild himself.
If I had driven two hours to pick up a supposibly good axle, you can bet I would not be willing to drive that same 2 hours back in order to drop it back off without some type of compensation. Why should 89 be penalized in money for gas because the axle was no good?
Someone is lying. We have no idea who it is. All we can do is offer up advice to both parties on the best way to settle it.
If 89 did nothing to the gearing then the axle was bad to begin with, and he needs compensated.
Your guess is as good as mine as to who's telling the truth.
