corerftech
Maybe not the most appropriate section to post this question or topic in, feel free to relocate as needed.
Building an ultra light 1987 std/std truck for street/strip use. It’s gutted (really gutted) and will fit NO specific class (and I don’t care).
it’s a really light truck with anticipated 475 hp. With just a bed, axle and bumper in back, plus a seat, steering wheel, engine/trans and cooling up front and inside- there is not much weight to send backwards.
I have contemplated moving the empty firewall back but it’s just cheaper/easier to leave as factory.
BUt like gassers from the 50s and 60s, I’d like to raise the crank centerline much higher to get some serious weight transfer happening.
Unlike a gasser I’ll have a reactive front end, meaning it will have shocks and coil springs and not a leaf and solid axle. It also won’t stick its nose up. But not having a good to contend with allows me to live the engine higher (and not rearward more than typical) and that will compound transfer.
So my concern/question;
carbureted engine
Blown
Float bowls need to be level side to side (engine for that matter) but also intake carb flange level front to back.
So am I raising the level engine straight up (altering the firewall relief and trans tunnel accordingly)?? Basically instead of a trans tunnel top of arch being around the hip height of a human, it’s probably several inches above that.
What I see is a really tall tunnel and firewall penetration. Entire drivetrain, without its slope altered from norm, moving straight up in the cab area.
This means my yoke will be very high and I’ll have to accommodate that with pinion angle to match as rear end is set up.
OR———
have I missed the concept?? What am I overlooking???
Headers will exit over the front tires and flow back outside the frame rails to the first bend and turn down.
I need some insight from someone who has seen a few gassers up close to see the trans tunnel and firewall pen for the bellhousing, and the engine bay- well enough to be able to speak into this.
I feel like it’s pretty straight forward! The possibilities are wide open endless with the carb being the single critical angle setting.
Again, what am I missing.
thanks in advance
mike in memphis
carbureted engine
Blown
OR———
thanks in advance
mike in memphis
