welderman85
- Dec 23, 2011
- Automatic
Hello I'm rebuilding my 1995 Dana 35. I'm currently trying to pull the third member out and found out I have to pull the driver side radius arm out. I have the knuckles pulled and the shafts out. My questions are it's supported with stands on the frame can I put a jack under the driver side ttb to hold pressure the undo the shock to release pressure off the spring to pull it out . Also any other pointers for pulling an arm
