James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Automatic
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
There was a jug of coolant in the cargo box that makes me think this is not a new issue.
Went round and round with dealer about it and they claimed no way the radiator leaks but they are wrong.
I have a mind to go back to them but the thing is I did talk them down quite a bit which is hard to do at a dealer and it wasn't an unknown potential issue to me plus it's not tons of money.
Here's the thing. I still can't find exactly where the leak is, but I -think- it's on the passenger side, on the side of the radiator about 2/3 way down which I think puts it pretty close to the mounting ears/tabs and it's been mentioned this is where it likely could be. It's a few drops when you park, say, less than a dozen drops. It'll leak a drop or 2 sitting there overnight. It doesn't stop me from driving it, but I'm concerned that a small leak could suddenly become a big leak (I don't know if this is likely, but it -could- happen I suppose) so I'm thinking it's smart to hold off going way up some dirt road to try 4x4 until I get this fixed. I'm tempted to just get a radiator and put it in and be done with it. As long as I've determined it's definitely not a loose hose or something stupid like that.
Right now this is the only thing mechanically I see that has to be done and I should chase this vs cleaning, polishing, admiring, etc.
What brand and/or supplier should I go to? Advance is over $200. I doubt OEM is available and shouldn't matter as long as it's a decent one.
There's also taking them to a radiator shop, that's what we used to do, but I'm thinking, taking it out/in isn't terribly hard but it is work so might as well go new, agreed? vs soldering etc if that's even possible.
And when I do that probably it wouldn't hurt to flush out the heater core. I'm getting massive heat so all that stuff is working good - maybe not necessary but shouldn't hurt either.
Basically I want to replace with a good quality radiator so wondering what other people have good success with.
