Rack and pinion bushings
Bryan B
Wasilla, AK
Anybody know where I can get some poly bushings for the rack and pinion for a 99 ranger?
Where have you looked? RockAuto? LMC truck? Summit?
For some reason I don’t think they have bushings. Pretty sure they are solid mount. They have inner and outer tie rods with bellows over the inners. Think the steering shaft just has a U-joint.
See attached photo.
I had mine apart not all that long ago and I didn’t remember bushings on mine so either mine doesn’t have them or they looked good enough I didn’t see a reason to replace them. I don’t remember searching and not being able to find them, but my memory isn’t what it used to be either
I replaced mine not that long ago and apparently the bushings that came with the new one aren't holding up.
Energy Suspension use to make a poly bushing fir just about everything.
I worked with a guy that had to make then for his Explorer. There was something he could buy that was close enough to trim them down and force em in.
