rabs modual connector
steamgas
Newbern
VA - USA
Vehicle
Drive
can someone help me find information on the abs modual for a 1994 ford ranger 4.0l 4x4? i need to know the pin layout and maybe the part number for the 14 pin connector. i need the female connector.
tex
Item Part Number Description
1. 601 (LB/PK) Anti-Lock Electronic Control Unit Feed
2. 512 (T/LG) Brake Fluid Reservoir Switch to Module
3. 519 (LG/BK) Rear Sensor (Low) to Module (LH)
4. 530 (LG/Y) Anti-Lock Electronic Control Unit to Chassis Ground
5. 210 (LB) Indicator Lamp to Switch (4x4)
6. 535 (LB/R) Pressure Switch to Module
7. 603 (DG) Failure Warning Light
8. 664 (Y/LG) Module to Release Solenoid
9. 601 (LB/PK) Anti-Lock Electronic Control Unit Feed
10. 523 (R/PK) Rear Sensor (High) to Module (RH)
11. 511 (LG) Stoplamp Switch to Stoplamps
12. 571 (BK/O) Anti-Lock Electronic Control Unit Diagnostic Ground
13. 599 (Y/LG) Module to Solenoid
14. 664 (Y/LG) Module to Release Solenoid
