quick question fender bolt
rangerraider1979
NW OHIO
1993
ok I have a question I have a 94 ranger and at the bottom of the cab were the fender bolts on is rusted what is bracket called that the fender bolts to on the bottom of the cab. under the door. and how easy is it to get off of a donor truck with out hacking all up...
easy stuff if you have the blood of a virgin, 3 gallons of holy water and 3 testicles of newt.
no seriously, I would consider fabbing something out of scrap metal. The issue I would expect is that anything you find wont be much better than yours.
yes it is welded to the cab I just wanted to know if anyone has had anyluck pulling the brace off or what the part name is so I can order one and spot weld another one on
