checked the fuel bowl its just at the sight hole were it should. still the same story guess ill check the timing next that has to be it ! iv had it running since the duraspark so i kno thats not it
try advancing the timing by turning the dizzy counter clock wise,not too much though.
I assume your holley has the #61 jets in it,sounds like the bowl height is just right.turn richness adjustment screws in until lightly seated,then turn each out i and i/2 turn and try it.if it starts,adjust the idle speed and after warmed up reset the timing.
next,put a vacuum guage on it,idling and warm up turn each richness screw in slowly until the higest vacuum is achieved,then back one quater turn.
next drive it for a few days and pull a plug,inspect the porcelain,white-too lean,pink or brown just right.if white,go up to the #63 and drive another day or 2 and recheck plugs.
