yeah thanks guys, im really starting to figure it out now, alot of what my highscool electrical teacher was teachin us hah. Once
I see the diagram i will get it, thanks again
ok so was doing some looking on crutchfield and found this diagram and i think this is how im going to wire my subs, http://www.crutchfield.com/Learn/learningcenter/car/amplifiers/sub_amp_guide.html?page=5
what yalll think about that set up? not sure about wiring the positive of one of the voice coils to the negative of the same voice coil but figured its legit since its on crutch field but how does that work? where that put my impedance at
thanks, but if i wire one sub to one channel and the other channel wont i not be gettin as much power to the subs as if i bridged them?
for example, say an amp is a 2 channel amp and at 4 ohms its rated at 125wrms x2, but that same amp is rated bridged at 4 ohms 500 wrms, or WAIT would that power then split and give 125wrms to each sub so it would be equal to if you jsut wired one sub to one chanel and the other sub to the other channel... ok I may have answered my own question, so basically its a whole lot more work to bridge a 2 channel amp to power 2 subs to get the same power as apposed to just running one sub to one channel of the amp and the other sub to the other channel in 2 different series circuits...right?
ok looked up some diagrams on on the12volt.com and think i have decided on my setup for subs finally! after alot of help from yall and alot of learning, i am going to run 2 of these http://www.sonicelectronix.com/item_14921_Polk+Audio+DB1240DVC.html
wired in parallel to this amp http://www.sonicelectronix.com/item_8651_Kenwood+eXcelon+KAC-X10D.html, that should get my 300 watts rms to each sub right? the amps a little more than what i wanted to spend but it should be well worth it
I'm having a hard time finding a 2 channel amp that puts out enough watts rms to each sub, im thinkin i may be better off gettin a mono channel amp, just need to figure out if i want 2 ohm or 4 ohm dvc subs and if i should wire themin parallel or series, well back to the drawing board i guess
EDITk looked up some diagrams on on the12volt.com and think i have decided on my setup for subs finally! after alot of help from yall and alot of learning, i am going to run 2 of these http://www.sonicelectronix.com/item_14921_Polk+Audio+DB1240DVC.html
