cjroddam
I got a 08 ranger 3.0 and ive done a few little things to it but i have a few questions, so read up. first off, ive removed only the airbox and replaced on the filter with a big cone filter(stock tubing to TB and MAF/Housing)...then ive had custom catback dual exhaust put on(single in/dual out Flow 30)...and just recently installed Diablo Predator 93octane tune and running 93 octane fuel(also advanced to time by 2% to compensate for exhaust and airfilter) also removed speed/rev limiters...truck runs so much better now and i can feel the extra power...i can actually run a/c with cruise on at 70mph and climb normal hills without it kicking it...also topped out at 121mph the other day
...nuff rambling, to the mod questions...ive been thinking about adding the following mods from Underdog Performance: Screamin Demon coilpack, underdrive pulley for crankshaft and alt, and a larger straighter air intake tube from MAF to TB.
Question #1: I know the underdrive will give about 8hp to a stock 3.0, im hoping to get maybe 10hp with my other mods but mainly ive heard that on some ranger 3.0's that the underdrive will cause it to overheat/cooling problems because of fan speed?
Question #2: The screamin Demon coilpack i know will add better more power spark across the board, but will it really be worth it to get it or will it actually make a difference in my case?
Question #3: Is there any other mods that are recommened for me to do without breaking into the engine(im still under warranty)??
