MrEwubbsZ
- Mar 7, 2011
Ive ever dropped a trans before this is going to be my first time.
from what i understand i need to.
Take out the shifter.
unclip the reverse light switch.
quick disconnect the line going to the slave cylinder.
unbolt the trans from the cross member.
then unbolt the drive shaft. ( question about this.)
unhook the ground from the battery
unhook the wires going to the started and remove the start.
then unbolt most of the bolts from the trans and hack up the trans enough to take pressure from the cross member.
Remove cross member.
then finish unbolting trans and bring it down.
This is probably way over my head but i have to do it because i cant afford to have it done.
The reason why i think i need to do this is yesterday i was backing up and my truck stalled even though i had the clutch pushed in so i start it back up and i couldnt put it into any gears so i turn the truck off put it into gear and start it and it starts to move before i even release the clutch it was tough getting it into gears but after about .25 mile it seemed fine. so problem shifting at all.
i drive it a bit more to see if it happens again and how whenever the clutch is fully pushed down it makes a grinding noise.
So from what i understand its either the throw out bearing. or the pilot bearing so i was just going to replace the pilot and put a new slave cylinder in.
Any and all help or advice will be greatly appreciated
Edit-
Is there any special tools that I need I heard something about a alignment tool?
And does the drive shaft literally just slid out of the trans?
Edit-
