Q about tech section
redeyed
CT.
I read how you can fit F-150 coils into the bronco II & ranger and the how you have to bend the front tabs out of the bucket to get get them to fit right and then fab a way to retain them, while not entirerly hard, I was wondering that if you could just install the F-150 bucket if you had one. Would this be an easy fix to the problem or more work than it's worth.
Thanx for any help guy's
modifying the original coil bucket works well... changing an entire bucket is allot more work for just the 150 coils.if your going big later put on a full size bronco coil bucket they have 2 shock mounts (i dont know if the f150 bucket does)
i swapped in my 150coils with ease and the tabs arnt hard to bend or remove, and ford sells coil retainer tabs or you can pick them up at a junkyard.
Thanx , that what I figured but if it had any benefit I would have went that route instead. Thanx again:icon_thumby:
