aipaul
- Apr 25, 2008
I recall reading a TRS tech section article on the Mazda M50D transmission a few years ago. I seem to remember it saying it could take either ATF or 90w gear oil. It said something about the gear oil being thicker which reduced the noise and kept it from splashing around and leaking from the shift rail plugs. Because of this article I was running gear oil for a few years until I read that gear oil in this transmission is BAD! Now I see the article has been revised and all mention of gear oil removed. Anyone else remember reading the article before it was revised and following this bad advise?
