- Aug 6, 2007
- Age
- 62
- Automatic
Ok, with the new intake adapter and the repairs to my intercooler I managed to get everything to fit. When I fired up the truck it sprang to life without trouble, but now I can't get the idle to drop below 2 500 rpm.
TPS settings are normal. Warm-up is normal, but my O2 sensor is reporting an extremely rich condition. If I go into the fuel table and back the fuel down, nothing happens, and that is VERY strange because it SHOULD be responsive.
I can't find a vacuum leak, but it's REALLY hard to hear anything because the engine is so loud. I've got all of my fittings on tightly and if I check each joint nothing happens to the idle speed.
Now, I AM using the Mustang throttle body that Dave sent me. It's got this weird idle stop thing that has no adjustment because it comes from the bottom. The engine responds to pedal, but simply won't go below 2 500 rpm.
*** edit ***
Also, in the midst of all this trouble I noticed that my interior fan was stuck on one speed. I tried adjusting it, but nothing happened. Then, all of a sudden, it went "poof!" and filled the cab with a cloud of smoke. The smoke dissipated, and while the fan still works, it only works on full blast. It's likely that I blew the rheostat that controls fan speed, but why?
After tighting everything up again, I checked the vacuum gauage. It's reading 20 inches of vacuum, which is normal, and when I take the truck out for a spin it goes into boost nicely. I just can't get the idle down!
***end edit***
Any ideas?
*** edit ***
***end edit***
Any ideas?
