- Aug 6, 2007
- Age
- 44
- Puyallup, Wa
1972
- Manual
Well, it's looking like it's time for the overhaul. In the next month or so, I'll be pulling the engine out for rebuild. IF I don't find a suitable donor in the meantime, the 2.3 will get a rebuild, nothing fancy, just a basic rebuild.
I'll also be redoing the exhaust (again), ujoints throughout, tranny seals, brake master cyl, front springs, rear springs, and I'm thinking about TG 26 spline birfields, just as insurance.
Tonight, I started fiddling with something I've been wanting to try for awhile now, and after alot of winching this weekend, I finally decided to add a hand throttle on the dash. I bought a cheap choke cable from the HELP section of the local parts store. It was $6.99. It is just the cable w/ sleeve, and handle, with a nut to fasten the handle to the dash.
I started by finding a bolt in the drawer to thread into the existing hole in the throttle cable bracket. I had to ream the hole out a bit, and tap it. Then I took the allen head bolt, and drilled the center out just big enough for the cable but not the sleeve. The sleeve fits down into the allen key recess. I have not decided how to retain the sleeve in the bolt yet, but one thought is a setscrew drilled into the side of the head of the bolt. Another thought was to just tackweld the sleeve to the bolt, but this would make engine removal more tedious. As for the attachment to the throttle linkage, I am experimenting around with a small rotating linkage assembly I made out of 1/8th inch plate, and a piece of 3/16ths inch rod. The linkage assembly basically has a pivot bolt up top, which bolts to another existing hole in the throttle cable bracket. In a triangle from this, there is a hole to the engine side of the linkage, with the dowel protruding out 1/2". On the outer side, is the hand throttle cable. Basically, when you pull the cable, it pivots on the upper bolt, and the dowel pushes on a set screw on the original throttle cable. This allows the throttle to be applied with the foot pedal, without the hand throttle pushing out of the dash.
I need to finish up a couple things on it tomorrow night, and I'll get the finished pics up.
Well, I thought I had a good thing lined up, but someone else got to it before me. I found an 87 t-bird turbo coupe on craigslist, had a bad torque converter seal, for $400 obo. It would have made for a badass swap in the LJ, but I still got time to look.
