wahlstrom1
J-man HD Mech
Forum Staff - Retired
2011 Truck of The Year
It's an inch longer, and when you can set the steering stops up and shim the cylinder to keep from over steering the joints.
Nice post terminals
The manual part didn't bug me at all, the part that sucked was I had to roll the bender out in the driveway and lock it into the trench drain. Rain or cold weather and I couldn't bend tube.
It's super fast, just wish I had a better way to retract the ram to make it alot faster.
Check the fitting going into the cyl. It might have a flow valve in it. Basically its a valve used to slow the liftgate descent if you pop a hose. Its looks similar to a check valve. For your application, you dont need (or want) it in there.
Remove that and add a return spring, you should be good to go.
