Preparing the Rat for winter.
Andy D
Marshfield MA
to prevent Found On the Road Dead, Fix Or Repair Daily
I have the Rat prepped for winter. After taking it for a ride around town, I stopped at my sister's to talk to my BIL. We got to talking about trucks, He is a Chevy guy and has a GMC version of the Colorado. It has vacuum shift on the front end and electric shift on the transfer case. He bought it cheap with issues, being ~12yrs old GM. It has air problems and flunked its annual safety and emission test. Plus the front end doesnt engage because it needs a vacuum line. I reached under the Rat. The vise grips are still clamped to where the shift motor should be. I used some white paint to high light the positions and the right point of the triangular shaft. The shift was firm and positive. this time I double checked to make sure that both of the hubs were set to free. Now, if I want 4 High, all I have to do is lock the hubs. I'm sorry , I lack the hardware and the smarts to post a picture. Why Ford would have an electric shift with manual hubs is beyond me. I may attempt to re-invent the wheel with a manual shift in the cab. Until I do I will use the present bodge.
that stays engaged with just vice grips?
never had good luck doing that.
likely somebody shitcanned the auto hubs and put the manuals on.
look around for a manual t case. then you can run around with the hubs locked and engage 4 hi on the fly.
Sometime it takes a little finagling. Today it slipped in and locked in first try . Once the truck goes forward in 4 wheel it locks in fine.
