rboyer
- Nov 11, 2007
- Age
- 42
the trans makes a slight noise sounding like metal being turned on a lathe, with the bit only barely touching the metal when you have the clutch out in neutral... noise stops when you press the clutch and i notice it's easier to shift into gear if you hold the clutch in for a few seconds before trying to select a gear...
And nobody replying seems too concerned with this? Although I haven't heard the truck with my own ears the first think that comes to my mind from that description would be eminent transmission failure. Be very careful, this is starting to sound like one of those nickel-dime trucks that end up costing a fortune in the end.
