PlumCrazy's Build
Another thing we haven't factored in is the actual rolling diameter of a big, squishy tire at 7-10 psi..lol
Eh, its just like school. "Ignore gravity, ignore friction"
Lol
Sent from my XT907 using CrapaTalk
Brad you could always do a 203/205 combo behind your ZF5. They are the same spline and will bolt up. You would just need teases and a doubler kit. Better low range, stronger, and you can still be 1:1 on the highway.
Moar goodies showed up today.
Tired of getting nasty looks from everyone at the park when I am wide open throttle..so decided to put a muffler back on. Used the have a Thrush 2.5" and loved it, its durable and has no packing to blow out. I am going to fix my joint where my stack connects too since every time it rains I end up with a half gal of water in the exhaust..
PlumCrazy's Build
New pre cleaner bowl to replace my cracked, yellowed one that I tried to night shade a year ago...
PlumCrazy's Build
I think I am going to powder coat the rest of the pre cleaner since it is started to surface rust
Picked up these from some guy for cheap. Should work and I will have extras.
PlumCrazy's Build
PlumCrazy's Build
I just painted my pre cleaner bowl.
Sent from my Rooted SM-N900T
I tried to tint it LIGHLY with night shade by applying it heavy and wet sanding it down to make it even, but it was a epic failure.. the paint caused the plastic to crack for some reason. I like the crystal clear look anyways.
Mine didn't stay clear long, maybe a few weeks before it turned yellow
Mine lasted for over a year. I bought it from the JD dealership last time. This one was an Ebay special...so it will probably be junk in month.lol
Not a whole lot going on with the truck, but I did decide to clean up the TSL wheels a bit.
Step 1...roll out of garage
PlumCrazy's Build
Step 2...wash and reveal original color
PlumCrazy's Build
Step 3... sand and lay a nice coat of white
PlumCrazy's Build
Step 4...recoat with most obnoxious shade of yellow possible.
PlumCrazy's Build
PlumCrazy's Build
I also popped the outer beads off all my wheels and swapped the rubber stems out for the bolt in type. and finally got the piece of tree bark out of the bead.lol Its been in there for a year and it never leaked.lol
PlumCrazy's Build
All four tires had a handful of sand in side too.lol Not sure how it got in there.lol
PlumCrazy's Build
That's a fugly shade of yellow lol.
Shoulda just left them white.
IDK about next weekend.lol Im planning on SOR the weekend of May 9th.
i have a gas RC car with the same color wheels lol
