PlumCrazy's Build
Did a little excel work for a few ratios/scenarios. The yellow shows where I am now and what I am working towards.
Basically..my new 5th would be similar to my current 4th, but with a little better RPM range for the freeway.
:icon_thumby:
I guess I will start taking my axles apart :icon_welder:
I need to final a crawl ratio calculator that includes tire size... im at 108.1 but thats without factoring in a tire
I have FPM in there
Sent from my XT907 using CrapaTalk
What setup gets you to 108?
Not an rbv. My main wheeler is a toyota powered sammi. Still have 2 rangers but ones about to be scrapped to pay bills.
22re 5 speed dual cases 5:29s. On 38.5" tsls
Kris, I made an excel sheet that tells you your speed at a given RPM and tire size with your gearing if you want that.
Edit: Note, its in mph... not kmh
My email is 036speed@gmail.com
I put mine inn Feet/Min since at slow speeds, when MPH is a 1.XX or 0.XX its hard to get handle of how fast that really is IMO
PSH.
That is a good point. Mine is now in FPM lol. A much better scale for crawl speed indeed.
^and the calculation is easier since there is no extra step for changing units of time.lol
I feel like there is a redneck joke in here....
If you truck is slower than a milling machine feed rate.... you might be a redneck...
Hmmmm.....
So I may need 2 cases or else I will be doing laps around you...
Looks like you need to go for that ZF/1356 doubler setup on 40's....we will be even....lol
Then there will be the B2...4.10s and 31s, no doubler, no ****s given...showing us how its done.lol
EDIT: Apparently TRS auto censors the f-bomb...
Another thing we haven't factored in is the actual rolling diameter of a big, squishy tire at 7-10 psi..lol
Event Coverage
TRS Merch
