PlumCrazy's Build
I didn't bring a whole trans... just an output shaft, reverse gears, and an extension housing.... I only bring things I have broke before.
I did get one off Escort at Bundy though.
Sent from my XT907 using Tapatalk 2
I dont think you wheel hard enough.. I mean your not bringing pistons with you...
LOL, you laugh now, I know a guy that drives around with a complete engine in the back of his truck (in parts) so he can rebuild his engine if he has too.
He also carries around a 350 turbo trans in case his fails on him.
Robert
posted with a 13mm spanner, and a flat driver.
Robert
Obviously he hasn't discovered Ford stuff yet....since he know the Chevy stuff will fail at any time :D:icon_rofl::icon_rofl:
L8r, John
I did have an extra short block in the truck at the Spring Roundup, but that was for different purpose... lol
Do you even wheel Bro? :D
No. Those damn speed bumps at the mall are hard on a vehicle. And it seems like every time I go shopping... I come outside to find another door ding or a cart that someone carelessly let roll away into my bedside....
A few pictures...
Checking the suspension droop.....or just trying to get out in 3 wheel..
I have some GoPro footage that I need to go through.. but Im not sure anything real eventful got recorded. I put it on the B2 facing reward to record me following, but he took a few bypasses where I didn't, so none of the hairy stuff was recorded. lol
Wheeled SOR all weekend.
Snapped a stub shaft, egged the other, busted a lens on a light, and lost a ext cab window.
Heres a few pictures...I have a lot videos recorded by a few buddies, but it may be a few days before they are up.
High centered..
Got sideways on a steep rock climb and had to tie off my slider to another rig to counter balance me while I worked it over.
Made it up the hill that we watched a Jeep flop on last time.
The B2 found a tree at the top of a long hill climb....
Dat shopping cart flex yo.
Don't you just hate it the way those darn trees jump out if front of you ?????????
Robert
sent with a rooted record player, and a eight track.
Are those pop out quarter windows interchangeable with the non-pop out ones?
No. The non pop outs are glued in, the pop outs have holes to be bolted on.
Took care of the window last night.
Upon closer inspection I discovered my trans cross member is destroyed.. I twisted it enough to shear a few mounting bolts off and miss align the holes...its pushed up about 2" so the rear case mount isn't even touching now. Its hard to see in pictures, but its bent just inside if the cutout for the driveshaft...
Wasted a trackbar bushing... I need to redo the bar and use a rodend, but I haven't got around to it.
And egged the driver stub pretty good..
I still need to tint my new window too...
