PlumCrazy's Build
Cant you use a stepside tailgate? Wait... you have a mesh one dont you.
So glad you didnt flatbed it.
I could use a steppy gate, but I like the visibility through my current gate.
Sent from my XT907 using Tapatalk 2
Plum, are you going to have Ranger at the show tomorrow??
Yep. The B2 and Brad will also be there. I read somewhere you can get a free banner with the group name is 6 or members come.
We wont be out until after lunch.
That's only if you pre-register. I can bring the previous Banner Across America to display (should of thought of this earlier), but I need some way to hang it and display it.
I'll be there at 11am.
I am only bringing my Dually, and my son and my wife. Too much of a hassle to bring the Ranger that length of time.
I hate that its not roadable...
Tore down three of my spare M5ODs to build a legitimate one.lol
Quick back story...
I bought the truck with a "recently rebuilt" trans. A week or two after I starting driving the truck the trans started making noise, then one day I just lost 3 and 4...turned out the shift collars were installed backwards and wore down the shift forks...so I built my first hybrid trans by just swapping 2.5L guts onto my 4x4 shaft and dropping everything as is into my 4.0 case... I just wanted to see how it worked. I liked it, but after two years the pocket bearing started making noise. Turns out I used a bit too much RTV on the front cover and the excess oozed in plugging the oil supply hole to the slinger that feeds the pocket bearing.
Soo bought a M5OD HD trans and another 2wd 4 banger trans as well as a rebuild kit with bearings and synchros. I built another hybrid and it was nice a quiet and shifted like butter.... but I decided to show off how a locked rear does a knarly burnout and snapped the output shaft off in the trans.
So I needed to get the truck going and needed it done quickly. I couldn't find any 4.0 4x4 trannies but I found a 3.0 4x4 trans local. I bought it and swapped guts in the school parking lot and got her going. I immediately noticed it chirped into 3rd and had pocket bearing noise... I said screw it and ran it for the last 20k.
In the mean time, I swapped all the 4 banger gears off the busted output along with the rebuild kit bearings and such onto a 2wd shaft left from one of the hybrid builds and dropped it into the 3.0 case I had from the last rebuild on the blue truck. I then used that 2wd 3.0 trans to 5 speed swap my 99 3.0 DD at the time.
So now 2 years later the trans in the blue turd is making all sorts of noises and getting worse by the day
I am using my original 4.0 case, the gears from my original hybrid, but I am using all the low mileage parts like the input, updated synchro assemblies, and reverse/5th from the HD trans. I picked up a 4.0 4x4 trans from a buddy that was stuck in 4th for dirt cheap. Im salvaging the output shaft out of it. The rest is junk. It looks like the the truck was probably stuck in the mud and they ran it in reverse long enough to starve the input and pocket bearing of lubrication. The first two synchros were melted, the input gear was trashed, the collar and bearing were blued from getting hot, the slinger was melted and in pieces, etc.
I also ordered all new main bearings, seals, and a shim kit to build this one right.lol
Case all cleaned up.
PlumCrazy's Build
Old synchro compared the updated coated one
PlumCrazy's Build
3 trannies apart at once....what could go wrong?
PlumCrazy's Build
Hard to see in the pic..but here is the trashed nose on the output from the first trans.
PlumCrazy's Build
It feels like 60 grit and has lobes.lol
Im taking all the stuff I am using to work to clean it up in the parrs washer to assure there is no junk in the needles.
And pics....also courtesy of Jim.
PlumCrazy's Build
PlumCrazy's Build
All i can say is screw that noise.....
Unfortunately... the noise has manifested itself into a Chewbacca growl...and no one screws with Chewbacca.
PlumCrazy's Build
My first wave of trans parts showed up, the rest of the bearings should be here by Friday.
PlumCrazy's Build
PlumCrazy's Build
The pocket bearing was incorrectly packaged, but Cobra Transmissions has awesome customer service and were able to throw the correct one in with my second order that was shipping out, so it doesn't hold me up a bit.
I strongly recommend them to anyone rebuilding a trans or tcase. They have unbeatable prices and carry all the OEM bearings for our trannies and cases.
Do they have a website?
Sent from my HTC VLE_U using Tapatalk 4
Cobratransmission.com
Brinker is the one who recommended them to me. He used them first for his transfer case overhaul.
