nktidwel
- Sep 26, 2008
- Cottonwood/Gordon Al
- 1995 (built in
I know this has been discussed, however I have not seen anything with the same symptoms (I read several). There is play when the wheel is turned to the left, from the "normal" posistion. I figured I would check what I could easily see. I bent over, looked at the joint in the cab near the firewall, its tight. I decided to move the wheel back and forth in the are there is play. The shaft didn't turn with the wheel. So that tells me the play is in the column somewhere... What should I check next?
BTW 1995 Ford Ranger, 2.3, 5sp.
Thanks
-Nate
Ps. Just realized, been a member since '08 and this is post 1...
Thanks
-Nate
