Evan
I installed some two-piece 4 degree alignment bushings on my Dana 35. Yesterday I noticed a bunch of play in the top of the knuckle. I thought it was bad upper joints, but realized the shaft of the balljoint is not being clamped enough....it is loose within the bushing. Even if I crank the pinch bolts way above spec the joints are still loose in the bushing. Has anyone else seen this happen??
