Picture of wire colors
82801
Wyoming
2.3 (4 Cylinder)
94 ranger clutch pedal position switch wires all were cut trying to rewire it new connector has all black wires .
Should just be two wires. Doesn't matter which way you wire it. It's just a set of contacts in the middle of the circuit.
Ford called it a clutch triple function switch for a while. It has 6 wires.
Here's the one from my 1992 manual
Here is the wire diagram I have for 94- 3.0l. This switch will be the same for all 94 models with the manual transmission.
Oops. I read that wrong last night in my EVTM.
Hmm. Functions:
1) "neutral" safety switch (prevents engine from turning over unless the clutch is held to the floor)
2) cruise cancel switch (cancels cruise control when you step on the clutch
3) Unknown (what would the third function be?)
Hmm. Functions:
1. neutral start
2. CC cancel
3. PCM signal
45537
Hmm. Functions:
Pcm input so the computer knows that the IAC valve is now taking over.
