Pics Of 2wd Ranger Lifts!
I cut the bedsides because the tires had already pulled them out. There was no point in pulling the bedsides when they got mangled already. So I removed the areas that got messed up. :icon_welder:
Idiot :thefinger:
More to this coming soon, check out my sig!
stock 2wd suspension 3" bodylift. 33x12.50r15 dick cepek mud countrys on moto metal wheels. 15x8 4" backspacing.
I can't believe you made that fit lol.
I'm going to be running roughly 6" of suspension lift with my 33's. Should be a breeze looking at this. lol
I guess they weren't lying when they said I could stuff 35's if I did flared fenders.
Anyone have any tips on lifting a 3rd gen 2wd? Kind confused on what route to take. I'm running 31s stock. Kinda want at least 3 inches of suspension lift. If I can go higher without changing brake lines, etc maybe higher. Kinda on a budget but let me know what I'm looking at.
if its beamed then i would do leveling coils and a 1" spacer. if its a arms then jus do lift spindles. and on the back you have a choice of blocks, shackels, or beefier rear leaf springs.
Idiot :thefinger:
sorry your the idiot for not checking your bedsides before ruining them :thefinger:
4 inch lift springs front, Autofab beams and radius arms. In this picture the 8.8 is out for a rebuild and the 7.5 and 3 inch blocks are in. The 8.8 is going back in without blocks and I am going to pull the bedsides. I have stock type shocks and extended bump stops in the front right now. After I get the 8.8 done I am going to F250 front shocks, 2 inch lift springs, and will likely trim the front fenders. Tires are 31x10.5 15 on 15x8 rims.
sorry pic did work before
[/IMG]
dude i seriously LOVE this truck!! The stance it has is perfect! and the wheels tires and dead on! so so so awesome! :icon_thumby:
2" spacer, 4.10 gears, 31" tires. The rest is in the sig.
Just like so. Bolts to the frame the same place the bumper does.
they were built by a member on here
