Pics Of 2wd Ranger Lifts!
trucks lookin good man, thats about the stance im lookin for after its all said and done, diggin the lights and allsouth sticker. hows it do on the trails?
stock 2wd suspension 3" bodylift. 33x12.50r15 dick cepek mud countrys on moto metal wheels. 15x8 4" backspacing.
Well, here's my 01 Edge. It's bone stock right now but I plan to crank my t-bars a little and then throw some 31x10.50x15 duratrac's on alcoa rims. I'll post a pic when that's all done.
Heres my beat up '08. Chevy 64s out back, shackle flip, torsion bar crank, sitting on BFG AT 32x11.5x15, minor bedside trim to fit the wheels with a bigger offset.
Stuffed rear wheel
up front
my truck does pretty good last time i went out i ended up having to pull a bronco out 5 times then just to piss him off went through the same stuff he just got stuck in
what it started out as..
thats after 2inch coil spacers, airlift bags in the back, and a 3 inch body lift.
still not done but so farhttp://therangerstation.com/forums/album.php?albumid=935&pictureid=7184 Im putting a 2-3 inch lift on the front to raise the hitch
Dude, you have me confused on this hitch install you did!! Why did you not put the hitch where it is supposed to be, Bro?? You have a rear hitch installed as it should be installed on the rear of the truck. What were you thinking, Bro?? You are dragging the ground looking for grubs?? lol
Here is how I installed my Reese 2 inch receiver hitch. I installed this years ago.
I have a PA bl as well as a suspension lift. I just can't see somebody installing a front receiver like that. Can't you relocate it now instead of waiting for a lift? If you can't do it take it to a fab shop and ask them how much to raise it where it is supposed to be. That truck will look so much better when you see that receiver in a better location.
Stuffed rear wheel
up front
why on earth dod you cut your bed sides?:icon_confused:
Seems to me that his tires would contact the wheel arch when fully stuffed into the wheel well. Take a good look at his second pic. If that wasn't trimmed, that tire would hit and would chew his tire up if he was moving.
yea so you pull the bed sides, not cut them!
:icon_rofl:
anyways, heres mine.
Event Coverage
TRS Merch
