Sponrad
- Jul 28, 2008
My 03 4cyl ranger has a phantom starting problem that I'm trying to figure out. Sometimes when I try to start, the engine only cranks and never turns fully on, just cranks and cranks. This happens about 1 in 15 starts at this point (varies). It usually occurs when the ranger has been sitting in the heat for a few hours before trying to be started, this could be a random coincidence however. So far the pattern has been that it will start up fine a few hours after having a failing start.
Things I have ruled out:
Battery- it is new and charges fine, the engine cranks very healthily, terminals and grounds are clean
Coil- suspected this at first and replaced it
Fuel- really dont see how it could be this since when it does turn on it runs fine, never chokes or bogs
Suspected:
ECU- this might be affected by the heat when the car sits in the sun, seems like electrical stuff would be messed up by that more than anything else
Fuel filter- its been suggested to me by a friend so Im going to go ahead and replace it, but i have my doubts this is the problem
Didn't throw up any codes when i got the computer checked; the check engine light does not turn on. It definitely runs fine when it starts so im fairly lost here. Two mechanics ive taken it to have had no suggestions either. It doesn't help when you tell the mechanics there is a problem and it starts ten consecutive times and runs fine in front of them.
If any of you have any ideas or suggestions they will be greatly appreciated, I'm beginning to lose it here.
Suspected:
