ItsA5Spd
What are the symptoms of a PCV valve going bad? Could this cause a rough idle? Also, where is the PCV valve located? Can I clean this one or should I just buy a new one and be done with it? IIRC, they're relatively cheap ($10-$12)? FYI, I don't know that it has ever been replaced in the 134000 miles that are on the truck.
I don't know if the PO has ever had that done. Thanks for the help!
