pats help
Nothing to do with pats..but back problems...
I put foxbody seats in mine, which are taller than the ranger seats and believe it or not.. gives more leg room. I've got the leg supports you pull out on the front of the seats..helps out a lot on trips. I have a jacked up back myself. I'm 5'10 and my son is 6'3.. he has enough leg room.
Foxbody seats sound like a great solution.
Remove pin 8 Black/Yellow wire from 10 pin connector and remove the Black/White wire from pin 1 on the 16 pin connector and install the pin 8 Black/Yellow wire.
Ya this doesn't work no change to tach reading, also I dont have blk/white wire in pin 1
