2.5L ('98-'01) P1131 diagnostic help...LOTS of data!
Featured Build Threads
masanders
Belton
SC - USA
Vehicle
Drive
2.5L
Don't get louder, improve your argument.
Evening folks!
I'm starting down the path to trying to figure out what is wrong with my '00 2.5L Ranger. I searched the forum and read all of the posts that have to do with this particular MIL code and have found a lot of useful ideas and symptoms that match what my truck is doing. I even consulted the Ranger tech section and will be using the O2 sensor article as a guide to help track this issue down. So far, research on The Ranger Station, BlueDriver OBD2 reader, and other forums point to the following possible issues:
  • Vacuum lines
  • Intake manifold gaskets
  • Mass air flow sensor
  • PCV valve or cracked PCV valve hose/tube
  • Clogged/Dirty throttle body valve
  • Upstream O2 sensor
  • Air leak between MAF and Throttle Body
  • Oil dipstick unseated
  • Leaking EGR gasket
  • Stuck EGR valve
    • Diaphragm or EGR Vacuum Regulator
  • Exhaust leaks before upstream O2 sensor
  • PCM - Engine computer
  • Fuse issues
I've pulled all the data I can from the BlueDriver reader and have listed it below. I'm sorry it's so long. I'm just trying to be as thorough as i can be. If you know much about sensor data, could you take a look? I'm planning on cleaning the MAF, checking the PCV and the hose, and cleaning the throttle body valve. I will also be running electrical reference tests on the O2 sensor and MAF. Unfortunately most of the to-do list relies on the next paycheck to come in, so it'll have to wait.
OBD2 Sensor Readings
BlueDriver with current firmware
2000 Ford Ranger 2.5L 4x2 @ 242,945 miles
Code: P1131 Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 1.
Did have P0171 Code: System Too Lean Bank 1. Code has gone away.
  • Mass Air Flow Sensor
    • Before Throttle Blip
      • 0.5 - 0.6 lb/min (4.01 - 4.38 g/s)
    • After Throttle Blip
      • 0.4 - 0.5 lb/min (2.95 - 3.83 g/s)
    • Key On Engine Off
      • .1 lb/m (.55 g/s)
  • Fuel System Status
      • Open Loop due to detected system fault
      • Closed Loop
    • Key On Engine Off
      • Open
  • Bank One Sensor One Voltage
      • 0.000v - 0.050v
      • 0.025v - 0.780v
    • Key On Engine Off
      • 0.005v - 0.010v
  • Short Term Fuel Trim
      • Started at 3.1% - 8.6%.
      • Changed to -17.2% - 42.2%
      • Held steady at 0.0% for about 10+ minutes until throttle blip
      • -92.2 (very briefly) - 9.4%
    • Key On Engine Off
      • 12.5% - 13.3%
  • Long Term Fuel Trim
      • 14.8% - 16.4%
      • 14.1% - 15.6%
    • Key On Engine Off
      • 0.0%
  • Other Readings
    • Absolute Throttle Position
        • 16.5%
        • 16.5%
    • Calculated Engine Load
        • 28.6%
        • 28.6%
    • Intake Air Temperature
        • 112°F
        • 134°F
    • Timing Advance Cyl 1
        • 8.0° - 9.5°
        • 7.5° - 12.5°
      • Engine Idle Speed
          • Between 948 - 970 RPM
Freeze Frame Report @ 242,800 miles
  • (02) DTC that caused freeze frame data - P1131 Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 1
  • (03) Fuel System Status Closed loop - using all oxygen sensor(s) as feedback for fuel control
  • (04) Calculated Engine Load Value - 48.2 %
  • (05) Engine Coolant Temperature - 170.6 °F
  • (06) Short Term Fuel Trim Bank 1 - 42.2 %
  • (07) Long Term Fuel Trim Bank 1 - 15.6 %
  • (0C) Engine RPM - 2200 rpm
  • (0D) Vehicle Speed - 46 MPH
Mode6 Data attached - too much to type up. I don't understand it anyway.
If you made it this far, thank you! I'm hoping you guys can help me think of things i haven't thought of yet.
Mark
Sound like you have list in roughly correct order. For sure vacuum leak is top likelihood.
I would start with checking for vacuum leaks. Also try to inspect the wiring for the upstream O2 sensor. Make sure it is plugged into the harness good, no broken or shorted wires.
How old are the O2 sensors? They rely on a chemical reaction and, therefore have a finite lifespan that ends when the material is depleted.
Eric...good to hear from you brother! I'm definitely going to start spraying to find the leak. I've read about using starting fluid or unlit propane. What would you suggest?
As far as the O2 sensors go, I don't think they've been replaced since I inherited the truck from my father. Even then i can't remember him ever replacing them or having them replaced. Off and on lean conditions have always been a thing with this truck.
I would probably use brake cleaner or startung fluid. Use the little red tube so you have a more specific idea of where a leak might be. If you just fog the engine bay and the rpm changes, all you van say is "yup. There's a leak somewhere."
I'm doing alright. It has been a strange and busy year for me. Hope you're ok.
I went ahead and checked around the PCV valve and found the area saturated with oil. I was able to pull the valve out very easily and couldn't tell if there was a grommet there or not. The valve rattled indicating it was fine. All I know is that it felt too smooth and easy to slide the valve out and back in. Once i get the area cleaned/degreased I can update.
For theory's sake, can a worn/cracked/missing grommet cause a vacuum issue?
Evening All.
I'm pretty sure my truck has a split personality now. I picked up starting fluid and a new grommet for the PCV valve, changed out the grommet which was definitely a source of oil blow by and a good vacuum leak.
Now here is where things get fun. Sunday, when i re-inserted the PCV valve, I was still figuring it was the grommet that was the issue. I figured that I would have the same drive-ability issues of:
  • P1131 Code: Lack of (H02S11 - Bank 1 Sensor 1 O2 Sensor) Switch Sensor Indicates Lean
  • Past P0171 Code: System Too Lean Bank 1
  • Rough idle
  • Poor fuel economy
  • Has bogged down to point of engine stumbling or dying
  • Tach needle has jumped 1K RPM without change in actual RPM or speed
  • Loss of power from a stand still if RPMs aren’t high - 2K-ish
  • AC will stop blowing out of main vents
    • Unsure if it is only blowing out of defrost vent
  • Codes/Check Engine Light has gone off and then came back on after a week or two
Since i re-inserted the PCV valve everything was essentially the same except now the idle would climb to 2.5k-3k. After i replaced the grommet, the high idle remains only while stopping, not while sitting parked. The upstream O2 sensor shows no voltage or that there is any short term fuel trim. They only show readings when driving under load. Then they look ok. The long term trim looks like it evened out around 16-18%, MAF readings are where they should be, idle is where it should be (parked) and it idles smoother.
While it was parked and at idle, i thought the idle was a little high, so i honestly gave the IAC a little whack. RPMs dropped noticeably, but not dramatically.
Not sure what's up. There are no codes or pending codes in the system.
The only time i got any real reaction from the engine when i sprayed the suspect areas with starting fluid was when i sprayed the IAC vent at idle. The IAC gasket didn't show any leaks.
Any ideas or suggestions?
Check your vacuum line going to the firewall. That is the vacuum source for the HVAC. Since the controls are all vacuum controlled, if it's malfunctioning, there's a vacuum leak
Here's the HVAC vacuum diagram. I had a cracked vacuum line going from the intake to reservoir and I lost all control of the vent selection. It also ran noticeably rough
  • P1131 diagnostic help...LOTS of data!
If it is complaining about running lean and your fuel mileage is bad I would suspect the oxygen sensor, like Eric mentioned they do wear out and when they do they report low voltage so will add fuel sometimes to the point of running bad...
If you climb up under there and see a Motorcraft number on the side of the sensor chances are it's factory and just gave up... I would start there...
Featured Ranger Based Vehicle
