- Feb 4, 2008
- Southeast USA
- Manual
Are you getting a CEL?
My 99 ranger with 3.0 has a leaking filler neck and wrong gas cap . The truck is using a lot of gas, could these be the problem? what would the codes be when testing?Thanks!
yes it is possible.
yes randy, its also possible depending on filter design and where you get fuel from, to never change a fuel filter in 300k miles over 15 years as well. i have seen that happen on a chrysler product.
i guess if you named it..."hey guys that never change their filters" maybe it could help keep money in your wallet changing it more then every four years of shitty running.
the whole point went past you that routine maintenance would have left you totally ignorant that simple filter changes could save you four years of running like shit and driving you nuts. now you know for sure a shitty filter can cause issues.
the filler neck runs a whole different scenario as well that i would have been willing to explain on the over heating....but i am too tired from patting myself on the back
i was serious about cleaning the tank out though....
Maybe I should have named it "attn anally retentive knowitalls"... I might as well have.
1) Outside of your virtual box of friends sparsely scattered across the country, nobody changes fuel filters routinely. Nobody. Conduct a poll and see (not online either... in real life). The vast majority of people who are having trouble with Rangers and coming here for help are going to have dirty filters.
2) The Ranger 3.0 will run lean and therefore hot with a plugged filter. Maybe other vehicles will too.
3) Extremely few mechanics are going to suspect a plugged filter being the cause of overheating. We've already had "decades worth of experience" say it can't happen.
When you take 1 + 2 + 3, we have nobody changing filters on a truck that will run hot if its not changed and nobody is going to be able to put it together. Hence why the thread is here.
The idea being someone (maybe a previous chrysler owner) will see the thread and think "Well a filter isn't very expensive and really should be changed anyway, so maybe I'll try that". And it might work for them.
Otherwise we have threads like these:
http://www.therangerstation.com/forums/showthread.php?t=129359&highlight=overheating
Everyone ran out of ideas and nobody suggested fuel filter.
http://www.therangerstation.com/forums/showthread.php?t=125167&highlight=overheating
No fuel filter again
http://www.therangerstation.com/forums/showthread.php?t=124500&highlight=overheating
Still nobody saying anything about a fuel filter. I'm not saying a filter was the cause of their issues, but it certainly could have been brought up! Search "overheating" on here and you'll get pages and pages of results. I've yet to see one mention anything about a fuel filter. But now you're acting like its common knowledge. Where were you with your 14,000 posts?
I'm not cleaning out the tank. The filter's job is to filter that trash out. If the fuel pump craps out due to it, then I'll clean the tank at that point while replacing the pump... maybe. If my truck overheats again, I'll change the filter. Otherwise I'm just going to drive it.
The filler neck is a recent issue and had nothing to do with overheating, but had a lot to do with big puddles of gas on the ground at the gas station.
i did not see where i was being a dick know it all in my initial posts.
i am not convinced yours was the filter altogether. just how many years is a tank sock supposed to last anyway?
there were many threads over the years where some were instructed on how to do a volume test and load tests with gauge. i tried to search for those and cant find them so no wonder you cant either its possible they are lost along with a shit ton of other data.. they would outline this issue in full. thats why i dont like to tell people to search endlessly...
just on the pic i suspect ethanol goo build up in your tank. that shit is horrendous and relentless if it sits long enough. you may or may not have an issue, i can see where you could care less to open it up...it is a pia. if there is an issue the slow build will cause other difficult diagnosis issues with sticky injectors etc....
if it was truly starvation or aeration or a combination of those the plugs should have indicated that as well.
and in a real world poll among my sparse friends, reading plugs and changing filters is common.
usually when fuel starvation is an issue for heat its because it needs a tune and bigger injectors to make up for the new h.c.i. because we the sparse few change the filter regularly and monitor fuel quality, plugged filters are not always an issue on the table.
but i live where we have blended fuel and the last 10-12 years its been a real issue with older seasonal vehicles. especially boats. it eats the nylon socks right off of the pump.....but you find that after the pump dies usually.
with this particular filter they like to plug easily so you must get good fuel for the most part, and lower miles of course....so many variables you cant cover it all, so four years is a legitimate surprise to me.
i am surprised about how you feel about the fuel filters not getting changed.
its easy to do and is a reason many do it. the majority of vehicles i see have non oem filters.
the thing with mcormick was not meant in that context...it was with the rarity of it being possible in this scenario and the vehicle actually operate with any power it all..
the h.c.i. scenario usually happens with a v8 swap and not heavily relevant to this conversation....but lean hot is a constant when building power
but i have some minor mechanical ability....and the reasons to change a fuel filter are constant..
reading plugs though and a vacuum gauge....the masses wont do that.
