Danger_Ranger_94
Hello all. I'm new to the forum. I've got a 94 Ranger with the 5speen 2wd. It's basically stock except an 87 mustang pausy rear end chunk. I've had an overheating problem since I've owned the truck. If you sit and idle it will never over heat only when the ac Is on. I thought the radiator was clogged up so I bought a 3 row full aluminum radiator. Bought a new fan clutch and went through two of them cause they stayed locked up (cheap aftermarket parts) so I eliminated the mechanical fan and put an electric 16" hayden cooling fan with a hayden universal fan controller. It's set to come on at 190 degrees and I have a 180 degree thermostat installed. The electric cooling fan and radiator didn't change a thing. Still heats up while sitting still with the ac on. The ac never blows warm either and the pressures stay perfect too. While I'm driving it's fine. It has a recent water pump and I've flushed the cooling system many times and put back in 50/50 mix green coolant. I've been a professional tech for about 3 years in a shop and can't figure this out. If anyone has some insight on what my problem could be it would be much appreciated. Thanks!
