Is it electric or belt driven fan? MOst likely its not electric, so when you shhut it off there is no airflow through the rad, the water is gonna heat up. When you restart and start pulling air through the rad and the water starts flowing again it cools off. All vehicles do that. Immediately after you shut it off the water stops moving but continues to gather heat from the engine. the sensor reads it and you see it. I dont think it overheating. I would still use your 50/50 mix though. Higher boiling temp.
