corona
Bout 3 weeks ago I pulled into a gas station to get gas. Turned off the engine, pumped gas, then when I went to turn it on.. well... it didnt turn on!! So I popped the hood and saw that a boot was completely off a spark plug. Thought it'd be as easy as plug and go but still nothing. I'll admit I had recently changed the plugs, I made sure they were properly gapped but clearly I didnt put a boot back on all the way.. After the new plugs the truck wasnt nearly as shakey as it was before. It ran perfectly for about 2 weeks until this incident. Ended up gettin towed cuz it was late.. Ive checked all the plugs and wires for spark and also the 2 coilpacks (2.3L 8 plugs). All checks out fine. The timing belt is still intact, and the fuel cutoff switch button didnt need to be reset. Not sure what else to do. The last thing I want is to have to tow it to a shop so any suggestions would be very greatly appreciated
