im in the middle of doing the one piece drive shaft swap im taking the whloe cross member out, to be able to cut the carrier bearing bracket off. i got the rivits cut off that go through the cross member and frame now the cross member wont come out it will wiggle a little bit thats it anyone run into this problem? while i was under there i also noticed my drivers side wheel seal was leaking
i just did all the wheel seals and bearings and brakes like 2 weeks ago WTH would make it chew up wheel seals that quick????
