one piece drive shaft? and wheel seal problems
bert296
UP MAINE
im in the middle of doing the one piece drive shaft swap im taking the whloe cross member out, to be able to cut the carrier bearing bracket off. i got the rivits cut off that go through the cross member and frame now the cross member wont come out it will wiggle a little bit thats it anyone run into this problem? while i was under there i also noticed my drivers side wheel seal was leaking :annoyed: i just did all the wheel seals and bearings and brakes like 2 weeks ago WTH would make it chew up wheel seals that quick????
When i did my 2 piece driveshaft swap, i just cut the bracket off to the crossmember with a sawzall. taking that crossmember off is just too big of a hassle.
That cross member is a structural member of the frame, it has weight bearing on it on both sides, maybe you could tap it with a deadblow up and get it out. Thats what i would try.
Honestly though, if it was me id put the cross member back on and cut that bracket off with a sawzall. Short blades worked the best for me. just my .02
and it's not like your ever going to use that POS 2 piece again
Dumb noob question about going to a 1 piece shaft from a 2 piece on a 94. 4.0 , manual 4x4 125" WB 8.8 RE ? What 1 piece will work.? TIA
i got mine at a junk yard for $50 out of a 99 x cab.
i got everything back together i ended up cutting the cross member in half and then welded it back together :icon_welder: after removing the carrier bearing bracket.
Dude... why all the extra work??
I just crawled under there, ground off three rivets, banged them out with a 3/8 extension
, knocked the thing off and good to go. :icon_thumby:
As a side note my truck is 125" WB and I used an 03-05 4x4 Sport trac shaft. More common in my area but it was more expensive.
if you have leaking axle oil seals that short after replacing them, then theres a issue with the axle where the seal rides, pitting, or excess wear would cause a leak. not sure if theres a s.s. ring made to slide over the axle (like they do for damper pulley seal issues) or if you have to get a different axle shaft.
Rascan is right. If you have a leak that quick something is up with the shafts. What was the reason for the bearing replacement?
I do have a pair of good 28-spline 8.8 shafts I'd sell. I'd have to get a price on shipping though.
I've had axle seals leak because the vent tube is clogged and the axle heating up causes them to blow oil like mad, i'd check that before I started replacing shafts
there was something wrong with the axle i pulled it out and the bearing had wore a groove in it like a quarter inch deep no idea why or what was wrong but i have a new one on its way from bronco graveyard
can anyone tell me the measurement of a 94 camaro v6 driveshaft?
