- Oct 18, 2007
- Automatic
booooooo to re-useing head bolts. Just get new ones when you do a rebuild.
what did you do to be able to pull the bolt out using the torqx bit?
I'm also curious..
You actually reuse head bolts (TTY or not)?
TTY = Torque to Yield, also called stretch bolts.
That head gasket really bit it! Sucks to hear, I know you just rebuilt that engine not too long ago.
I just installed my GT40 heads on my 5.0L last night (and a couple other things), and I definitely used new head bolts.I bought ARP bolts with the stepping washers since my heads were drilled to 1/2" to be on a 351W.
You know it's torque to yield when it says to pull them to 60ft# and then turn them another 90 degrees or something.
I've speculated why they switched to this. Anyone know?
I know where there is some Gt40 heads. Would I benifit from them at all with my speed density Fuel injection or would that just be pissing in the wind?
