On a scale of 1 to 10...
There's no spacer in the kit. And the only flywheel I have is the auto 2.9. Which has no spacer.
Sent from my Casio G'zOne Commando 4G, it's the John Connor of Smartphones. You cannot kill it...
Using Tapatalk.
Looks like you'll have to source one from another 2.9L or 4.0L flywheel at a junkyard then if you can't find one elsewhere.
10-4
Using Tapatalk.
columbia pull-a-part had one a few weeks back when i was there, may have what you need man
Negative. I get notifications for all B2's that hit PAP, and I raid them day of.
Using Tapatalk.
Does your notification include Rangers? For that part they should be the same.
Yes, but there are no pre 97 4.0 manual rangers out there right now.
Using Tapatalk.
if one off a 2.9 would work i may have one before long
I don't think so, but someone may know better than me.
Using Tapatalk.
Does anyone have a picture of what this spacer looks like?
Using Tapatalk.
So, I spoke with a rep from LUK and in the end, he was as boggled as I am as to why the pilot bearing doesn't fit.
Is this it?
No, that's not it.
My buddy had one laying in his shop and it doesn't change anything.
Using Tapatalk.
Unfortunately I never took a pic. It's just a small metal piece about an inch or so long. I.D. fits the pilot bearing, O.D. fits into the flywheel hole.
One from a 2.9L flywheel should work... At least if that's where mine came from... I know for sure I didn't have to buy it when I did my clutch swap.
The flywheel I had was an auto and it's like the picture I posted above.
What I need is a sleeve, I contacted the local Ford dealer and he's got one on the way for me for a few bucks.
Using Tapatalk.
