Harleroy
- Feb 20, 2008
I've got an '88 Ranger with a 2.9. When I bought it, the motor was in pieces. I put it together with new parts and it ran great (for 30,000 miles) until a few weeks ago. I came off the highway and rolled up to a stop sign and my oil pressure light started flickering. A little higher RPM and it goes out. I changed oil and filter (it was near due) and used 10W40 like always. I still have the same problem. I'm laid up due to rotator cuff surgery so I took it to a mechanic for him to check/change the pressure sending switch. He put a gauge in it and said there's not enough oil pressure after the engine gets up to operating temperature.
Where would you guys go from here? New oil pump? If so, can that be done in the truck? If so, what's involved? Not the oil pump, what do you think it is?
