Oil pan
rcone65
Attapulgus
GA - USA
Drive
Hey guys I know I asked somewhere way back what oil pan is needed for 98 302 to 96 ranger I'm thinking 79-95 mustang is this correct and best place to buy it and oil relocation kit
Thanks
I suspect you're right, I used an oil pan for a late 80's/early 90's Crown Vic interceptor when I put the 351 in my 93. Also, use some good motor mounts- meaning NOT ones from Anchor.
Thanks
Does your Ranger have TTB? Or is it torsion bar and rack&pinion steering? I don't think you meed to change it if you have the torsion bar setup.
The TTB Rangers require the older 2 sump oil pan used on the Mustangs because the crossmember is different. I can link to that oil pan when I get home, since I recently bought one.
1996 should be TIB/TTB, both will need the dual sump pan setup.
Well, in that case, this is what I ordered. However, It's not actually in the Ranger yet.
