Oil pan
rcone65
Forum Member
Attapulgus
GA - USA
Drive
Hey guys I know I asked somewhere way back what oil pan is needed for 98 302 to 96 ranger I'm thinking 79-95 mustang is this correct and best place to buy it and oil relocation kit
Thanks
I suspect you're right, I used an oil pan for a late 80's/early 90's Crown Vic interceptor when I put the 351 in my 93. Also, use some good motor mounts- meaning NOT ones from Anchor.
Thanks
Does your Ranger have TTB? Or is it torsion bar and rack&pinion steering? I don't think you meed to change it if you have the torsion bar setup.
The TTB Rangers require the older 2 sump oil pan used on the Mustangs because the crossmember is different. I can link to that oil pan when I get home, since I recently bought one.
1996 should be TIB/TTB, both will need the dual sump pan setup.
Well, in that case, this is what I ordered. However, It's not actually in the Ranger yet.
Was doing ricks ranger mounts
Kinda what I was thinking, but u will need new bolts if like mine it's a 98 and aluminum pan so bolts are longer than steel, the aluminum pan wouldn't go in place because I think it was the thickness of it, it is a double sump . Did u get a oil filter relocation kit yet
The donor is a 98 mountaineer rack and pinion 96 ranger is not . The pan on donor is a double sump but wouldn't sit right I believe cause thickness of aluminum pan not sure but definitely wouldn't sit down all the way
Yeah, different dual sump. You need the one like what Eric posted.
The one you have is great for 98-11 trucks, not 83-96
Ok thanks, what about oil filter relocation kit brand
This thread has some discussion on that.
  • Oil pan
I don't have a need for the oil level sensor, my stock pan has the port for it and it seems to enjoy leaking for the fun of it.
I like that the Ford kit doesn't have the port for the oil level sensor.
Cheaper may be thinner/easier to warm and harder to seal as well. Cheap chrome stuff seems to like to rust as well.
Debating transferring the sensor to my new pan. Not sure I want to drill the hole. I left the wiring in the harness just in case.
