oil pan
joey74
Vincent Ohio
Can anybody tell me what all fords that had the dual hump and dipstick port?
All fox body mustangs and fox body Fairmonts and others. Lincoln Mark series did also. All the trucks, 1980 thru 1996 had rear sump oil pans, which would work I would think also without the dual drain plugs.
Some pans had the dipstick made in the pan, some had it in the block. The block needs to have the spot back there for the dipstick. I am not sure the early blocks in the 70's had the spot for the dipstick. If it doesn't, make sure the pan has the provisions for the dipstick.
If you are converting a engine to a rear or dual sump, you will also need the extended oil pickup tube, and the special main bearing stud to support the pickup.
